Footer Options
The Footer Options Section will help you define your site footer layout and style.
Footer Layout↑ Back to Top
On this section, you can change your website footer layout.
  • Full-width Footer: You can choose if you want to have a full-width footer. The footer contents will take the full available width.
  • Footer skin: Select the skin you would like to have for your footer. Options are light or dark.
  • Transparent Footer: Select if you want to have a transparent background footer.
Footer Widgets↑ Back to Top
It is quite normal to use widgets on website footers. That way, you can customize it as you want. On this section, you will be able to select the number of columns you would like to have for your footer widgets section.
  • Footer Columns: Set the number of columns you would like to have for your footer widgets section.
Footer Extended↑ Back to Top
This section refers to the bar below the footer widgets section. This website section is often used to display the copyright.
  • Custom Copyright: Select this option if you would like to insert your own copyright text.
    • Custom Copyright Text: Insert the text you would like to have as the copyright text.
  • Display Social Icons: When enabling this option, you will make your social icons visible on the footer extended section (they will appear on the right part of the section).
Back To Top↑ Back to Top
The back to top button is the button you often see in the right bottom part of many websites, working as a link to the top of the page when the page is already scrolled. On this section, you can enable the button and customize its design.
  • “Back To Top” Button: On/Off, you can enable or disable it.
  • “Back To Top” Button Style: You can use the default style (one arrow only), outlined (transparent with a solid border and arrow), or solid background. If you select outlined or solid you will have more options:
    • “Back To Top” Button Shape: Round, Circle, Squared.
    • Back To Top” Button Background: Select the color from the color palette.
NOTE: Many of these options can be overridden on a page/post/portfolio basis.
