With an “Icon Box” you can add text with some sense. You can pick from more than 4 different icon libraries and more than 1000+ icons.
Icon
- Icon Library: In case you want to include an icon in your Separator, you must pick an icon library first.
- Icon: Select the icon.
- Module Position: Specify where the icon is positioned inside the module.
- Layout display: Specify the display mode.
- Media Icon: If you want to use an image instead of an icon you can upload it or select it from the media library.
- Icon animated: If you upload a SVG you can choose this to be animated.
- Color: Select the color from the color palette.
- Icon Background Style: Select a background style if you want one for the icon.
- Icon Size: Select the icon size.
Text
- Title: Insert a title for the icon box.
- Title Semantic: Specify the element HTML tag.
- Title Size: Specify the icon box title size.
- Title Line-Height: Specify the title line height in pixels.
- Title font-weight: Specify the title font weight.
- Title text-transform: Specify the title text transformation.
- Title letter spacing: Specify the letter spacing.
- Title text color: Select a color from the color palette.
- Use theme default font family: If you don’t want to use the theme default font family and pick your own, just untick this option.
- Font Family: The font family
- Font Style: The font Style.
- Text: A Rich text editor to insert a text below the title.
- Reduce text top space: Activate this to reduce the text top margin.
- URL (Link): Add a link to the icon.
- Link Text: Add a text if you want to have some kind of “Read More” link below the text.
Animation
- CSS Animation: Add some type of CSS animation.
- Animation Speed: Specify the entrance animation speed in milliseconds.
- Animation Delay: Specify the entrance animation delay in milliseconds.
Extra
- Extra Class Name: Add an extra CSS class if needed.
